here is one for the mechanics out there. My old maverick would struggle to start. Batt fine but you think it was that, got starter reconned,3 month later does it again. Starter fine (what was wrong with it in the first place then?). Got it going, three month later, same happens? Turns out poss batt terminal had loose cable? Still didnt think it was this like? Anyway its done it again!!!! What do you lot think?
starter motor
Broken, loose or disconnected wire/s in the starter circuit?
Bad connection in the ignition switch?Last edited by BUSHWHACKER; 17 July 2006, 11:04.
I've had a car do this. it turned out to be the starter just gets a bit gummed up springs get tired bushes stick etc etc just age really. if you can get to it easily try giving a whack with something heavy, that's often enough to wake them up.mudnstuff.me.uk
Has to be the starter motor? I have got it started by jumping it. Took it for a good run. Volt meter reading is 14v, drops down to 13 as expected. Went to start it and it a no go??? As if batt was flat. All terminals i can see are cleaned up and refitted. Alt has even been checked.What comes around goes around!!
