Hi MY surf failed the MOT today on the back brakes not working at all including the handbrake. So I brought it home and began to strip down the brakes got the first drum off and voila cylinder not moving whatsoever.
Was about to start stripping it down when I thought id just see if there was any fluid present. No fluid. Went underneath and bled the junction box thing then bled both back brake cylinders and I now have back brakes. The question is I have had the surf for just over 4 months and have always thought the brakes a bit $$$$ is it possible the back brakes have never worked since having it or what could cause the air to get in the system slowly and gradually without any movement in the fluid level?
It also failed on the fog light not working however that was due to the tester not flicking the correct switch even after telling him which it was before leaving it.
