Ac Help Please!!
    NOW I'm Confused...............
    Posts on here tonight say that if the green light flashes then the gas is low.
    If the green light doesn't light up then the gas has dropped to low and cut off the supply.
    So as my green light stays on when you turn on the ac does it mean that I could have a faulty relay or something?
    The green light stays on and the compresser doesn't turn around on the engine. I have done a voltage test and found that their is no voltage to the compresser.
    The fuse under the glove box is ok............ could it be a relay problem.? if so, where would I find it please?
    I'm not sure if the re-gass is gonna sort the problem if their is a break in the switching.
        while on the subject
        Should there be a hissing sound coming from the passenger foot well when its on.??
        I cleaned the inside of my Surf and must have hit button accidentaly and while driving i heard a kind of hiss So just switched the thing off and never tried it since!!!
        www.scottishmudclub.com for scottish events
