the weirdest ting happened tis morning...I finished a 12 hr night shift, came out tot he car park and found my rear windown wide open....I ran around the back thinking some scally had broken in only to find the window nicly tucked in its recess in the door....
...I got in the car as i needed to go home and sleep badly, and found that it wouldnt go up using the button on the gear box turret.
I got out and tried using the key - nothing....just a noise that sounded like twanging the tab on a can of coke...
I got in the front and made for home and now and again when I pushed the up button and the window went up down up down up and up and down and then down and stayed down. I managed to drive the 50 40 miles home and not get gassed by opening all windows in the car...
When home I got someone to push the up button while pushing the window by hand. Got it up and took the main fuse out so I could sleep without worrying....
Any ideas on what this could be ? solenoid or motor or just a dodgy conn ? where to start ?
many thanks...
Ron.
...I got in the car as i needed to go home and sleep badly, and found that it wouldnt go up using the button on the gear box turret.I got out and tried using the key - nothing....just a noise that sounded like twanging the tab on a can of coke...
many thanks...
Ron.
