starting the 2.4 diesel
  • starting the 2.4 diesel
    Hi, I am not new to diesels but found this morning my surf which i bought only yesterday was reluctant to start. I waited for the heater light to go out then cranked her over. Plenty of cranking power fromn the batts but no willingness to burst into life. Eventually I pumped the pedal a coupla times and she spluttered into life.
    Normal? or is there an accepted "procedure" or do i need to be looking for new glow plugs or anything.
    Thanx to you fine folks in advance.
    Al.
    I used to have a surf me!
    Al.
    Try waiting for a little bit longer after the light goes out, you should be able to hear the click of the glow plug relay and then turn your key.
    I'm a custard donut monster
      Thanx Jon, Will try that in the AM.
      We are up the A1 filming a rally in a forest this weekend and will be using the surf.
      Al.
        When I start mine for the first time in the morning, I turn on ignition, and wait for the beep (the beep is after you hear the clunk) , switch off and wait for the beep again then start. Seems to give the glowplugs a bit more heat in them.
