Servicing in Bristol UK
  • Servicing in Bristol UK
    Hello all
    New member on this forum - looks damn useful!
    This time next Saturday, I should be the proud owner of an imported 1995 2nd gen Hilux Surf SSR-G 3.0TD (recaro interior and manual box too! drool)….
    Bought it from its 2nd UK owner with UK SH, which is cool.
    Its due its 5000mile (or thereabouts) service and I was wondering if anyone had a recommendation for a trustworthy garage in the Bristol / Avon area for servicing.
    Also, what does the 5000 mile service involve?
    I have a good friend who is an ex plant mechanic (Volvo Cat machines) who would be able to help me service the truck, but I just wanted to check what this actually involves to keep the Hilux running sweet. Details of what needs to be done and where to source the necessary spares would be really good.
    Any help much appreciated..
    Dan
    get parts from Milner off road or roughtrax or toyota
    change oil, air/fuel/oil filters, belts (inc. cam belt if it's unknown age)
    change coolant, top up washer bottle, bleed brakes, check disks/pads/shoes/drums, grease drivetrain.
    plant fitter mate should be able to do it no problem as it's just like any other diesel engine.
    filter kit is about £15-20 from milners... much cheaper than getting a garage to do it and peace of mind that they haven't cut corners! but keep receipts as proof of servicing.
      Excellent stuff mate
      Filters should be easy, but is there anything awkard about greasing the drivetrain or changing the coolant? I guess I need to know where all the grease nipples are? Let me know
      Also, do you really need to do the brakes every 5000 miles?
      Once I get the hang of it, I would definitely trust myself rather than a garage (especially with a plant fitter mate to assist!)
      Thanks loads for the advice
      Dan
        Check the brakes twice a year, especially the fronts, when changing the oil is normally the least you should do, plus the props have grease nipples on each UJ. that should be grease at the same time.
          and if you click here,http://www.tpassmore.fsnet.co.uk/ToyotaSurf/files.htm you will find a card for your sun visor that tells you where the uj s need greasing..
          it's in me shed, mate.
            im yet to cheack the brakes (started to jingle a little now so are they on the way out?) and im also yet to grease it up underneath... i cant find the right size nipples anywhere - guess ill have to order some online
            Ive done 15,000km since Ive had her already, nice
            Tim
              Originally posted by Pleinmont
              Hello all
              Dan
              you could try brownstone in bitton they sale jap imports them selves so they no alot about them and they have a full garage service or if you speak to barry at roghtrax he will point you in the right direction
                Cheers for all the advice guys
                Esp the local info and the Visor note - genius
                Ta
                Dan
                  Hello all
                  Dan
                  hey dude,
                  seeing as you're in bristol, pop out to keynsham and speak to barry at roughtrax, http://www.toyotahilux.com he can supply you any part you might need, and... you can collect it to save on postage......!!!
                  he has a mate round the corner from his place who's started doing servicing on surfs and hilux pickups.
                  btw. welcome to the funny farm. let us know when the 'new owner' smile starts to fade....... !!!!!
                  see ya'll
                  Planty
                    Originally posted by Planty
                    hey dude,
                    see ya'll
                    Planty
                    Excellent mate - local spares AND a specialist garage - cheers for the tip.
                    Definitely glad i joined this forum.
                    Laters
                    Dan
