bugger all that!... i'm gonna stick veg oil in the truck and keep the diesel for the surf!! $$$£££$$$ kerrCHING!
Veg oil fuel ??
Originally posted by FlySurfer - Edy.Dude, respect to you and all but I sure do hope that HM isnt reading this ! LoL.
Of course HM Inspector of Taxes
is or will be aware. Keeping track of all veg oil used.
Used oil filter down to 5 microns at minute seems to be ok, bit more of a smell that fresh but as I do a lot of m/way long distance work its not to noticeable.Dave ssrx 3.0td Ltd auto Gen2
if you see a bright yellow truck/van in your area signwrittenOriginally posted by ssrxOf course HM Inspector of Taxes
SAFETYKLEEN
chat him up.{not like that] the filters they use in there machines go to
2micron'sEnjoying Life after Cancer
Pops
Sorry been so long since last report, been busy.
Still running 50/50 mix and all going well, little bit of a smell but nothing to drastic. Fuel/oil bill down by £80 pw and falling, once recycled oil kicks in will fall loads more.
Will report furtherDave ssrx 3.0td Ltd auto Gen2
steve ssrx
i have been watching you, [no not like that]
i have been watching and waiting with antisipation your -posts on the
progress of your veg-oil trails.
i have come to the descision it is time for me to cash in on the obvious
money savings to to made here.
what do i need to do to set my surf up for the veg-oil experiance.Enjoying Life after Cancer
Pops
Go for it Pops,Originally posted by popbriscoesteve ssrx
I'm still using the vegoil with no ill effects since starting this around april.
Veg-onMaurice
thinks i will, wot doineed todotoset surf up to take it?Originally posted by MorrGo for it Pops,
Veg-on
and what ratioshould i start with?
popsEnjoying Life after Cancer
Pops
Unless you want to run on close to or 100% veg-oil or waste veg-oil you should not need any mods at all.Originally posted by popbriscoethinks i will, wot doineed todotoset surf up to take it?
pops
Just add the new oil to the tank (preferably near empty) top up with Diesel to mix and away you go.
As to ratio, the highest vegoil content I've used was 66%, currently using 0% since running out of fuel yesterday! but next refill I'll be putting anywhere from 30-50% in, depending on how much oil I've got in the shed. You can get away with higher ratios in the summer as there is no risk of the veg-oil gelling at low or sub-zero temperatures.
I'd sugest starting off around 20-30%. The veg-oil can loosen crude from the bottom of your tank (altough I had no problems with this) and if this happens it may lead to your filter clogging. Best to change your filter before you start and carry a spare. after a few tanks if you're happy take it up to the 30-50% mark. Come summer you can take it even higher, beyond 66% has not been tried to my knowledge in the surf, indeed I'm the only one I'm aware of that has taken it this high, but other makes have coped with greater percentages, its all about experimentation!
You should also take some time to do your own research using some of the links posted earlier in this thread, or elswhere on the net.
Good luck Veggin, and let us know how you get on.Last edited by Morr; 3 December 2003, 09:23.Maurice
should i change fuel filter first?Originally posted by MorrUnless you want to run on close to or 100% veg-oil or waste veg-oil you should not need and mods at all.
I'd sugest starting off around 20-30%. The veg-oil can loosed crude from the bottom of your tank (altough I had no problems with this) and if this happens it may lead to your filter clogging. Best to change your filter before you start and carry a spare.
Good luck Veggin, and let us know how you get on.Enjoying Life after Cancer
Pops
I haven't been back to this thread for a while. Good to see the progress being made. I am only dabbling at the moment, throwing in the odd 5 gals, but it is hard work pouring it into the filler from the drum.
Im seriously considering fitting a second tank in the void where the spare wheel carrier used to be. I could then start on deisel and switch over to vegoil when the tank has reached a sufficient temperature.
The vegoil tank could be heated by modifying the exhaust system. I wonder if thats the way to go? Could get an interesting exhaust note too!It's only a hobby!
Here I can pick one up from any motor factors, I'm sure its the same in the UK, most people here seem to reccomend milners, I sure one of the others can point you in the right direction.Originally posted by popbriscoeok thanks buddy.
one more question and i'll leave you to get on.
where do i buy fuel filter from?Maurice
thanks mate will get sorted and post when up and vegginOriginally posted by MorrHere I can pick one up from any motor factors, I'm sure its the same in the UK, most people here seem to reccomend milners, I sure one of the others can point you in the right direction.Enjoying Life after Cancer
Pops
