Just a quikie...
I'm starting my 2" suspension lift tomorrow, I can't make out from either my workshop manual or a search on here - If I'm using spring compressors do I need to unbold one end of the panhard rod (or any other bit of the suspension unit) when changing the rear springs.
The manual asumes you're NOT using compressors, so I can't work it out. I'm also changing the shocks at the same time as well - so any pointer on this front would also be helpful.
It all seems pretty straight forward.....
Cheers,
Paul
Nil Illigitimi Carborundum
