Hi hope someone can help me. When I start my truck which is a 94 3.0td surf ssxr. When it starts I have all power then after 10 minutes or so the engine light comes on and then no turbo unless I come to a complete stop then slam my foot to the floor the light goes off then have the power again soon as you
Loss of power from turbo
Yes because the faults need to be cleared after you have done a repair. You need to remove a fuse for a minute or so but I have forgot which one . This will delete the error from your ECU, if it's been addressed. If you Google it you can easily find out which fuse you need to remove. Also 14 is turbo
