Loss of power from turbo
  • Loss of power from turbo
    Hi hope someone can help me. When I start my truck which is a 94 3.0td surf ssxr. When it starts I have all power then after 10 minutes or so the engine light comes on and then no turbo unless I come to a complete stop then slam my foot to the floor the light goes off then have the power again soon as you
    Trying pulling the fault codes. Cheers
      My codes I found are 14 22 and 24 but have changed the sensor by the air box and still the same
        http://www.troublecodes.net/toyota/
        Check this page. You have addressed point 24 but not 14 and 22. Cheers
          Have changed the air temperature sensor but the code 24 still shows up
            Yes because the faults need to be cleared after you have done a repair. You need to remove a fuse for a minute or so but I have forgot which one . This will delete the error from your ECU, if it's been addressed. If you Google it you can easily find out which fuse you need to remove. Also 14 is turbo
              Ah, I have googled it and found it : you remove the EFI fuse ( in the fuse box in the engine bay, behind the battery), leave it out for a minute , then put it back. That should reset your faults .
              cheers
                Ok thanks I'll try that now all the pipes to the turbo are good but on the top of the engine at the back are to little boxes with a vacuum hoses on them two go to the egr and the other one goes no where and can 'ot find where it should be.
                  Oh ok, maybe you are on the right track with that loose pipe...good luck!
