What tyre size and from where????
    No they are not their an inch taller, standard is 265/70R16....
    I have been advised they should fit though.
    Nissan Patrol for on-road, and a Land-Rover 110 shed for off-road :-)
      Originally posted by Tiger View Post
      How do you tell what the overall diameter of the tyre is?
      the best way is to go on a tyre companys website and get there details
      99.99% of the time a tyre is NEVER the size listed. a 33" BFG mud is 32.8" tall when fitted to a 10" wide rim.
      an Interco TSL is 33.7" tall when fitted to a 10" rim
      Also, a bfg 35" mud is 34.8" So its not that much bigger then a TSL 33"
      food for thought
        just been to look at mine yep duff info from me mine are 265/70/16
        Originally posted by RodLeach View Post
        reads in at 32.8"x11.50" Its classed as a 33" tyre.
        Good man!
        my converter thread said 31.18"
          bear in mind that only reads as 0.5" around the whole tyre. they will be bigger but dont expect to be shocked at there size mate.
            I am hoping the extra inch will be small enough to ensure they don't rub at max articalation...
              Thats the standard size for 3rd gens.
              I went up to 285/75/16 with mine.
              (thats 32.8 x 8.4 x 11.2)
                ok, might have wires crossed mate.
                a 285/75/16 is 32.83" tall. an so i guess on a 15" rim you will lose an inch off that total
                Those tyre sizes are the only ones affected by rim size. eg. 265/70/16 will be bigger then 265/70/15.
                but a 33x12.50 or 35x15.00 per example will be the same size no matter what rim diameter.
                  Mud Skipper,
                  Sorry mate, i read your post wrong!
                  I see you put 285/70/16 - i was thinking 285/75/16!
                  I dont believe a 285/70/16 is available.
                  • #24
                    It shouldn't be a problem. Ive been running 265/75/16 on my 2nd gen - 1st at standard height and it wasnt a problem at all.
                    with a 2" lift and 30mm spacers they rubbed on full lock for me. now with a 5" front lift - the poor s0ds look lost!!
                    • #25
                      Originally posted by The Lang-Shankit Scunner View Post
                      Measure height of tyre and wheel combined
                      Sorry badly explained if i want to buy a 31" tyre how would i know it's a 31" trye
                      www.cnpbetterhomes.co.uk
                      • #26
                        31x10.5x15
                        • #27
                          Originally posted by marky View Post
                          31x10.5x15
                          How does that relate when on the tyres its got 265/75/16
                          • #28
                            The calculator works well, would just like to understand it
                            • #29
                              265 is the width of the tyre in mm.
                              75 is the height of the sidewall as a percentage of the tyre width
                              16 is the size of the hole in the middle in inches (the size wheel it fits)
                              any clearer?
                              =SOLD UP!=
                              • #30
                                ie;
                                265/75R15
                                to work it out...
                                265 (mm) X 75% X 2 = 397.5 mm
                                rim is 15 inches (381mm)
                                OVERALL DIAMETER or Height is 778.5mm (30.65")
                                1993 HiLux Surf (mine)
                                1998 RAV4 (hers)
