Originally posted by grassy
Hi Grassy
Wired mine in to the control unit behind rear panel. Yes you need to switch to neg (earth). If I remember correctly its Green/yellow for down and red/yellow for up. Sounds like your system will need a couple of relays to do this. You wiil only be able to do this at centre console if you have altered the wiring there to be allways live (even with ign off) or you have allready run wires from the window controller to the centre console, which , reading your post you may have allready done. Hope that helps
John
