Originally posted by McWibble
No more broken fog lights
Maybe ILLEGAL check with your local MOT man as it maybe too highOriginally posted by caseyji have a 91 surf gen 2 with the reverse lights either side of the number plate, could i turn one of these into rear fog light??
nah - shd be fine - I once had a car with side lights up the side pillars - fog light was at the top and much higher than the number plate on a surf.Originally posted by markyMaybe ILLEGAL check with your local MOT man as it maybe too high
Just FYI for anyone thinking of converting a reversing light in the rear cluster into a fog light. I did this, but it gave me problems because when reversing out of spaces in car parks people couldnt see the reversing light as my rear mounted spare hid it from one side.
I got RAV 4 fog lights from a breaker for £5 each and one day Tony will mount these into my rear bumper. Until then she hasnt had a fog light for years!!
Linda
www.4x4toys.co.uk
i will be ok, no rear mounted spareOriginally posted by Lindanah - shd be fine - I once had a car with side lights up the side pillars - fog light was at the top and much higher than the number plate on a surf.
Hi I convertied both my reversing lights into fog lights as the standard reversing lights were a bit naff could'nt realy see behind in the dark. I did this so I could put 2 front fog lights on the back as reversing lights. No more probs in the dark now plenty of light.Originally posted by Lindanah - shd be fine - I once had a car with side lights up the side pillars - fog light was at the top and much higher than the number plate on a surf.
Just remember to cover the white lense with red lense tape also paint the bulbs red with heat resistant paint.The wheels on my Surf go round and round
My surf is a non tailgate spare version (has the reversing lights next to the number plate in the centre of the tailgate). I swopped the lights over from one with a spare on the bracket which also had reversing lights. I then bought 2 high power red LED lights and wired them up as fog lights. Jobs a goodun, they are extremely bright. Haven't mot'd it since and not sure what the rules are on white clusters for fog lights but I can always tint them.
Here you can see the finished result:
http://i22.photobucket.com/albums/b3...re_dump024.jpgLast edited by Snoop; 16 November 2005, 19:59.Real trucks don't have spark plugs
Originally posted by john.sallyanyone know the regs on hight above ground level for fog lights, i was wondering if i could use my high level brake light as one????????????????
Fog Light has to be within 18 inches of the offside rear light clusterParanoid? They're out to GET YOU!
