Just finished fitting fog lights into the back bumper. I got sick of buying new ones every time I want out to play. It was not a hard job to do, it was all done in one day, but if u are going to do it don’t put them as high as I have done. The underside of the bumper is not flat, so put them below the rubber tread that should be fine. I think it was well worth all the work and I like the look of it and the big thing is no more new fog lights to buy.
No more broken fog lights
looks good, nothing wrong with threesomes now and again.Originally posted by ohsupremebeingJust finished fitting fog lights into the back bumper. I got sick of buying new ones every time I want out to play. It was not a hard job to do, it was all done in one day, but if u are going to do it don’t put them as high as I have done. The underside of the bumper is not flat, so put them below the rubber tread that should be fine. I think it was well worth all the work and I like the look of it and the big thing is no more new fog lights to buy.[COLOR=red]Simon [/COLOR] '91 2.4td ssr-x
[QUOTE=marky]where did you obtain these fine looking lights from chris[/QUOTE
They are just standard fog lights for £6.99 just cut off bracker and cut hole in bumper glass on out side reflector box on inside of bumper long screws job done
All that’s on show is the glassLast edited by ohsupremebeing; 15 June 2004, 23:34.xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
What about replacing the driver's reverse light with the fog light?
Took my friend 5 mins to rewire it, all I needed was a red bulb.
Saves a lot of cutting and hassle![COLOR=Red][SIZE=3][FONT=Arial Black][FONT=Arial]MMMMMmmmmm 4x4[/FONT][/FONT][/SIZE][/COLOR]
Isn't this illegal? I have an idea you are only allowed two rear fog lights. In fact just looked at the Construction and use regs-would you believe that if the vehicle was built before 1 April 1980 there is no limit on the number of rear fogs!!! After that date two max.
what a silly law.. sure the more you have the safer you are???
I cant stand people who dont use fog lights, more to the point i cant stand people who use them in sunny daylight! how some pass thier test I do not know!
Tim
silly laws r us... i nearly got done under driver hours regs because i had a 46 minute break then 20 minutes later on!... wouldn't have been illegal to have 25 minutes followed by 20 minutes!... shorter breaks but within the law!... it's crazy mental!Originally posted by dirtydogwhat a silly law.. sure the more you have the safer you are???
hi,Originally posted by ohsupremebeingJust finished fitting fog lights into the back bumper. I got sick of buying new ones every time I want out to play. It was not a hard job to do, it was all done in one day, but if u are going to do it don’t put them as high as I have done. The underside of the bumper is not flat, so put them below the rubber tread that should be fine. I think it was well worth all the work and I like the look of it and the big thing is no more new fog lights to buy.
Is your rear fog light an ordinary bog standard one or is it a bit more attratcive if so where did you get it from?
thanks
AL
Bog Standard from Halfrauds as CHRIS had my old ones because the brackets snapped while offroading.Originally posted by alg1hi,
thanks
AL(\__/)
anyone know the regs on hight above ground level for fog lights, i was wondering if i could use my high level brake light as one????????????????Originally posted by markyBog Standard from Halfrauds as CHRIS had my old ones because the brackets snapped while offroading.Surf.gone but not forgotten
disco now gone aswell
