Fuel Pump
  • Fuel Pump
    Hi all, I nee a fuel pump for my 1989 2.4td mechanical.(NON EFI)
    If you have one in good working order please PM me, ta.
    Rob
    Still working for the man!
    Fuel Pump
    Hi Bob - i've got one spare although i have no proof (other than the say so of the chap i bought it from) - long story blew my original 2.4 engine bought a replacement with all sundries - the engine is sweet as a nut - fuel pump should be as well - assuming its the correct spec for you. pm me if you're interested.
    Steve.
      Steve.
      You have mail.
      Rob
        Surfsteve, can you post some pictures of the fuel pump, and tell me if it came from an EFI engine or not.
        Doner vehicle will need to be 1990 or earlier.
        Rob
          Rob
            Originally posted by plumb bob
            well out of 2 years on here that is a new way to get a post count up
              Just wanted to see my name right down the list, I was bored.
              Rob
                i thought you were gonna go thru the whole forum for a minute
                  Interesting thought, but I think it would take too long.
                  Rob
                    worth a try to see how far you get
                      I think maybe admin might intervene, and/or people would reply and knock you off the top slot again and again, you would be forever going round in circles.
                      Rob
                        bump
                        Fuel pump still leaking, new one needed or easy repair ideas!
                        Rob
                          bump
                          Bump
                          Rob
                            Bump
                            Remind me where it's leaking from, gasket? seal?
                              It appears to be leaking from the o ring between the disdributor block and the pump body, at the back, so can't see exactly due to the engine is in the way.
                              All the info I've read up on says that the pump will (probably) have to come out, and there in lies the expense.
                              If the pump has to come out and be re-fitted, it's about £400 labour, then injection specialist to strip, re-seal, bench test and recalibrate, about £350-£400.
                              Cost of new pump- £2500.00 from toyota.
                              OUCH!
                              Rob
