hey keith have you drawn the blueprints for your proposed rad. mod
yet?
do you want to share it with us ?
as i for one fancy doing that too.
I'M ALL
Blueprints ? ? good god man we never use them, will show you on sunday
You might want to bring a digicam to take pics of any part of interest.
Especially the fan that will be on the back
Keith
Keith
Hi Martin
Jotto and my good self are also mid Suzi build . We are ditching the fixed fan from the engine as all this does is throw muddy water over the engine , see Keith's engine pics . I have aquired a rad with electric cooling fan from a Mazda , but any similar car would donate a suitable rad and fan . As for the cooling fan switch , I will drill a hole in the top of the rad near the top hose then solder a nut onto the rad and screw in a donor switch . A relay and supply from battery and job done . Sounds simlpe , but proberbly take best part of a day to make up mounts for rad and fit all up etc .
Hi Martin
Better perhaps to put the fan through a dashboard switch, and just switch off to go in water. Otherwise your fan could still run in the splosh. We will run the fan all the time on the rear, and just let the thermostat regulate the block temp
Keith
i can see we going to all have a good natter over the tea/soup and cakes on sunday CANT WAIT
