i bought a brand new set of 2, Sparco 3 point harnesses for £40... is that a good price?
Harnesses
Originally posted by da SLUG manRight, got some for tony, but that's all he had left!....
will pop round, um, tomorrow?... got them circlips i PM'd about??
I'll swop 1 for the belts?4x4toys.co.uk - Keeping you on and off the road...
Do you need to harnesses to run through the seat like a bucket seat or not?
We need to fit some belts to that funny buggy thing Im off to collect but not sure the best way to fit them (to seats/frame etc)Tim
Originally posted by dirtydogDo you need to harnesses to run through the seat like a bucket seat or not?
We need to fit some belts to that funny buggy thing Im off to collect but not sure the best way to fit them (to seats/frame etc)Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
the top strap(s) should run horizintally to a bracket on a roll cage if possible... not vertically down the back of the seat... otherwise when you crash, your shoulders get pushed downwards and crush your back!
try and get a bucket seat with the harness holes in it... like wot i got.nee nar nee nar, i'm a fire engine!
Originally posted by da SLUG manthe top strap(s) should run horizintally to a bracket on a roll cage if possible... not vertically down the back of the seat... otherwise when you crash, your shoulders get pushed downwards and crush your back!
for the time being thought we could weld in a horizontal bar behind and use normal seats?Tim
The horizontal bar on cage method is much better then mounting to the floor, though I have had 2 cars with them mounted to the floor. If you do mount harnesses from the floor - as Rick says, always weld plates underneath and try to mount them far back from the seats so that they are not vertical up and then down.
Is the bar you are going to weld in part of a rollcage?
I'm in the process of trying to sort the 6 point harnesses for our 205 at the moment!Last edited by Snoop; 2 October 2005, 18:25.Real trucks don't have spark plugs
Originally posted by SnoopIt is possible to do this if the seats have headrests, you can just run them underneath - however, it's not a good way to use harnesses as they can move around too much, opening you up to all sorts of neck, back and chest injuries.
I'm in the process of trying to sort the 6 point harnesses for our 205 at the moment!Tim
