The Vagrant lives
  • The Vagrant lives
    The vagrant is alive, after all Ricks hard work the suzi is up and running again.
    I'm a custard donut monster
    Good job! This weekend inspired you Rick?
      Done most of the work over the last 4 weeks . New clutch , new tyres off a bloke at The Pit , fixed broken wiper linkage and replaced 1 wiper blade clip , Jon and Adam built a new heavy duty Suicide Seat base . Rear brake disc kit not yet fitted , all parts there just need to get round to doing it .
      Today we just put the wheels back on and gave it a run up the yard .
        Looks like it's almost ready for some mud - or at least some thick dust
        Roger
          got mine in the garage at the mo up on axel stands have to put new rear shoes and brake cylinders on just got a new clutch off of ebay for the 413 for £36 and got to get the radiator repaired as i broke the holding bracket off when i took it out last week so give it a couple of weeks hopefully and be back on the road.
          how easy/hard is it to fit a clutch on a sj413? thanks for any replies
            I have not done one on a 413 but it may be harder then the 410 as 5 speed box is bigger then the 4 speed 410 box .The 410 box had to have the floor bashed in to allow the clutch arm clear .
              just need to sort mine now,,, maybe I have a bit of time today to try and sort the water pump out. It need a couple of hoses too.
              Not decided if im taking ours to WildTracks or just the Surf what do you think? My girlfriend will be driving offroad that day for the first time and Zuki has NO brakes!
              Tim
                Originally posted by dirtydog
                ..............and Zuki has NO brakes!
                Ours got no brakes either , unless we fit the rear disc kit . Adjusters have backed themselves off when going through deep water . Pump them twice and we get a pedal . One option is to clamp off the rear brake hose and only use front brakes . Will not matter at low speed as long as front wheels are on the ground
                  i think some seals have gone in ours so same as you a few pumps and you get brakes!! which is fine unless you need to stop on a slope
                  we usually go to WildTracks and never had a problem without them so why start now?
                  Tim
                    good job rick
                    bring on some MUD now hey
                    Enjoying Life after Cancer
                    Pops
                      Just back from our lols.
                      Must get the Zook ready for 18th September.
                      It's only a hobby!
                        17th September clean the CARAVAN
                          Clutch out again
                          Pulled the gearbox back out the zook this afternoon . New clutch is slipping . Only took an hour including moving it , jacking it up etc . Pressure plate is ................. pressureless . No grip on clutch plate . No obvious reason , it just got no grip . Going to buy another clutch , this time it may be a genuine Suzuki one or at least a QH .
                            notice n e ware on flywheel, just a thought.....
                            CHEERS JOHN................
                              A little wear but I am sure it is not to bad . The pressure plate did have grip when fitted , so feel it is a poor quality part we fitted .
                              Flywheel is 'stepped' in the middle so it has a raised surface for the clutch plate to run on .
