Originally posted by stormforce1067
410 clutch
thanks for that Rick i am certain that i sent the bit back from the log book when i taxed it but obviously i haven't so i will go and check and get it sortedOriginally posted by Vagrant No2Richard
Your Zook was first registered 3/1/1989 . 6 previous owners and 4 private/cherished plate transfers . Not declared scrap or SORN . Recommend you get that last bit sorted mate.
will appreciate that too Phil
thanks to you bothhttps://www.facebook.com/groups/henpals/
Hockey cokey clutch
Took the g'box back out the 410 today as I was not happy with the feel of the clutch pedal . I was correct to as the release bearing had come of the release arm . Prob was caused by the arm hitting the trans tunnel on the way back in .
I refitted the bearing and lock wired the release arm back so it could not drop the bearing off if knocked . The g'box would not clear the trans tunnel unless the arm was moved forward , dropping the bearing .
I then consulted the 'service update bulliten' in my head and the g'box went in.
The 'service update bulliten' in my head instucts the use of a 'Jotto owned 5lb lump hammer' . With this in my hand the trans tunnel allowed the g'box to fit with no clearence probs .
Only fault is the clutch pedal will not go down due to the trans tunnel now stops pedal travel as is now under the pedal instead of by the side of it !!!
Will have to recheck 'service update bulliten' as to rectify this .Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
good luck mate
just started stripping our zook down to change a suspect water pump. will you be out in the vagrant on 29th Aug?
Originally posted by Vagrant No2Took the g'box back out the 410 today as I was not happy with the feel of the clutch pedal . I was correct to as the release bearing had come of the release arm . Prob was caused by the arm hitting the trans tunnel on the way back in .
Will have to recheck 'service update bulliten' as to rectify this .Tim
Me and Jon discussed wether the zook will attend 0n 29th , we are still unsure . I fixed the wipers today so we will be able to see where we are going !! . Repaired the alternator Kitesurfphil gave us so all charging now . 'Suicide' seat in the back being repaired with new frame which we hope will not collapse .Originally posted by dirtydoggood luck mate
Still got the rear disc brake kit to fit .
The old 'Vagrant' is having quite a lot of attention at the mo . About time to .Rick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
Originally posted by Vagrant No2Me and Jon discussed wether the zook will attend 0n 29th , we are still unsure . I fixed the wipers today so we will be able to see where we are going !! . Repaired the alternator Kitesurfphil gave us so all charging now . 'Suicide' seat in the back being repaired with new frame which we hope will not collapse .
Go on you know you want too!Tim
Hi Jon could you find out a price for a clutch for a sj413 jap model please and rough guide on p&p to camborne cornwall thats if they will postOriginally posted by jottoThe clutch kit cost an extortionate £37.60!!!!!!!.
The guy does sell all parts separately so if you just wanted the clutch plate give me a shout and i'll get a price for you.
thankshttps://www.facebook.com/groups/henpals/
Hi, do you want the whole clutch kit or just the clutch plate?Originally posted by stormforce1067Hi Jon could you find out a price for a clutch for a sj413 jap model please and rough guide on p&p to camborne cornwall thats if they will post
thanksI'm a custard donut monster
I'm glad the alternator was useful.Originally posted by Vagrant No2Me and Jon discussed wether the zook will attend 0n 29th , we are still unsure . I fixed the wipers today so we will be able to see where we are going !! . Repaired the alternator Kitesurfphil gave us so all charging now . 'Suicide' seat in the back being repaired with new frame which we hope will not collapse .
It's only a hobby!
Thanks for the alternator Phil . I fitted it but it would not charge , the same as the old one . Jon stripped it down and we found the brushes had stuck away from the armature . A quick WD40 and it all went back together with only 1 screw left over (broken) !! Now charge light goes out so assume it is charging .Originally posted by kitesurf_philI'm glad the alternator was useful.
Originally posted by Vagrant No2Thanks for the alternator Phil . I fitted it but it would not charge , the same as the old one . Jon stripped it down and we found the brushes had stuck away from the armature . A quick WD40 and it all went back together with only 1 screw left over (broken) !! Now charge light goes out so assume it is charging .
cant you just check the battery when the engine is revving with a voltmeter thing?Tim
