Not posted down here for a while so here we go .
Removed the gearbox from the silver 410 today as the clutch had started to slip badly when last used .
It looked quite a simple job except for the 1/2 ton of Pit clay/mud/chalk under the vehicle and around all the bolts .
With the 'box out the clutch was dropped out and was found to be worn out . Trouble is it has worn out on the flywheel side and damaged the face of the flywheel . It is not worth skimming it as not used on the road .
