New Zook Update.
  • New Zook Update.
    I have had a good look around the new purchase and done a few bits to it.
    Bad bits.
    • I had the carb off and checked it all out. No blocked jets but plenty of wear here and there, so I have a Weber on the way to replace it.
    • There is a noisy valve in No 4 position. I don't know if it is inlet or exhaust.
    • The clutch is very noisy when engaged and the box is in neutral. Noise goes when the clutch pedal is pressed.
    • The brake master cylinder needs new seals.
    • I have no charge light on the dash. Two wires hanging off the alternator and the battery has gone flat on me.
    Good Bits.
    • Nice seats.
    • Leather steering wheel cover LOL
    • 2" Shackle lift.
    • Extended props for above.
    • Free-wheeling hubs.
    • Nice offset 8 spokes with big chunky Technic Trackers.
    • Custom high mounted rear bumper.
    • All solid body (apart from the sills and osf wing).
    • All the lights work!!!!
    It's only a hobby!
    so how long b4 you get to play in it phil?
      Got my Weber carb in the mail yesterday. Well I would have if the postie hadn't knocked the door, run like a whippet and driven off before I got the front door open. I had to collect it from the post office this afternoon.
      I am going to have a go at making my own adaptor plate. It looks straight forward enough. I reckon I can do it with a pillar drill and taps/dies.
      The only problem is I also got a modified inlet manifold that will take an SU carb, so I am spoilt for choice at the moment. They reckon that the SU carb is the better converson as it doesn't flood when going over bumps and climbing/descending at over 45 degrees, but the fuel pump needs to be tip-top.
      The short answer is that it may be a little while. It'll be worth it in the end.
      It's only a hobby!
        top tip...
        rip off anything loose, SPOA conversion, rad in boot... drive
          top tip...
          you can come and do mine then slug and save me doing it lol
            I have a shiny SU converted inlet manifold sitting on the filing cabinet and I am collecting a HIF 1-3/4" SU with BBW needle tomorrow.
            I am having problems sourcing a brake master cylinder repair kit, so I was thinking of getting an anchor!!!!!
            It's only a hobby!
              if you cant get 1 phil give me a shout for what you need and i can have a look down here and post up to you if it helps you out
                FAO kitesurf phil
                http://cgi.ebay.co.uk/ws/eBayISAPI.d...544805320&rd=1
                i saw this on ebay i dont know if he will have anything you need for your brakes
                Richard
                  I cant find a repair kit either and no one seems to sell seals. the fluid has stripped the inside of the wing quite nicely too
                  Tim
                    this guy on ebay is a breaker and he has the SUZUKI SJ BRAKE SERVO/MASTER CYLINDER FITS ALL i hope this will be of some help to either of you
                    http://stores.ebay.co.uk/SJ-UK_W0QQs...Q3amesstQQtZkm
                    Richard
                      cheers mate ill bookmark him.
                      Tim
                        Cheers bud. I think I am going to have to resort to the unthinkable. The Suzuki main dealers in Leighton Buzzard.
                        It's only a hobby!
                          you tried ADK yet mate?
                          Tim
                            i found out a price down here for a new unit and it was £140.00 so at least you got an idea of how much a new 1 will cost
