I am still rebuilding my Lotus when I can . I need the help of an electrician to answer this question . I am running a new main cable from the battery mounted in the boot to the starter solinoid under the bonnet . Question is : I have removed the old cable which is 10mm copper with a few strands and want to replace it with a new cable which I bought at the Uxbrige show last year . This cable is multi fine core and also 10mm copper . Can I use this or am I going to loose amperage under crancking conditions ?
I want to use this cable as it more flexable and easier to route through the car body the the old stiffer cable .
Rick
Rick
