Body Lift Kit
  • Body Lift Kit
    Is there any preference to any make or type of 2" body lift kit? Is metal preferred or the urethane type ones just as good and any particular supplier that is recommended?
    TIA, Nick
    "The force will be with you, always!"
    Ask Scottlee
    Very recent thread ref body lift kits
      its all down to choice,really.
      the most important thing is the correct grade bolts,unless they are zinc plated and 8.8 shear test or higher,preferably .
      i have Ali on my truck,just because i was running a job at the time that i could use the material for,Delrin (polyacetal) would be my go to material normally.
      i know people have Nylon kits, but it is not a structural plastic,so dont be tempted by the cheap kits. i would also avoid the kits that are 50mm in diameter,they are known (from what i've heard) to punch through the rubbers. go for 60mm ,a much better bet,more contact for a start.
      but the bolts are the thing that does the work,so thats the weak link if any.
      nylocs and stainless steel washers a safe bet too.
        Thanks for the info. Scott, can you supply or any kit you'd recommend?
        Thanks
          actually,i have just made 5 kits for the meet that the facebook club are having at the end of may,sadly they are all spoken for.this is the kit i based mine on.
          http://www.ebay.co.uk/itm/2-Body-Lif...08798770&rt=nc
          but i did make some for surfenstien, and the guru's at Over Fabrication,early this year,might be worth having a word with him,im sure they have some kits left.
          hope that helps,mate.
            Scott..... facebook club ???????????????????
            There is only ONE club for Surfs
            & it's not a chat room
              Thanks again Scott, and that was one of the kits I was looking at
                Its the one I bought...seems fine so far.
                  PM sent to you.
                    I've heard good things about the lift kits from here:
                    http://xpajun.com/index.php?cPath=97...1add687353d4b1
