What springs can I use on my saggy arsed '94 surf. I want to give it a bit of a lift as well. LC 80 rear springs will give it a bit I know. They way I understand it though is that they are a different diameter so wont seat properly. Anyone know of any others that will do the trick?
lift springs
ShayneJ fitted some range rover springs there are/were some pics up in the general section I think?Originally posted by The Boo Crew View PostWhat springs can I use on my saggy arsed '94 surf. I want to give it a bit of a lift as well. LC 80 rear springs will give it a bit I know. They way I understand it though is that they are a different diameter so wont seat properly. Anyone know of any others that will do the trick?
How is the rebuild coming along bud?Originally posted by muddle View PostHow about actual lift springs designed to fit an actual surf? Check roughtrax.Eat.Sleep.Surf.Repeat.
This is the thread that you're looking for, Dave.
http://www.hiluxsurf.co.uk/showthrea...t=79793&page=2
I'm only just down the road from you. If I can help, or if you want to take a look at taller springs and a spacer, set up with taller dampers, give me a shout." Time wounds all heels ".
