So,
In my magical head movies a 2" lift looks pretty simple.
Then I noticed that some kits come with brackets for rad and bumper...and some are without.
THEN I noticed that I need to add magical spacers in something kind of steering doodad - because it's rack and pinion rather than rhubarb and custard? or something?
THEN! It got me thinking about my Auto gearbox and whether I needed to add any thingumybobs to that as well so it didn't bugger up.
So my first question is...can anyone recommend any kits that come _with_ the associated brackets and gubbins for a Gen 3 auto Hilux?
Assuming that answer is "Gibbons"
Then my next question is, has anyone put a 2" body lift on a Gen 3 hilux and if so what did you do to make sure you didn't ######## up the Gearbox and steering?
Cheers for your time and patience chaps!
Ant
Edit : I'm also aware that there's this magical thing called a Diff. I think it uses some kind of arcane gubbins to do with angles and stuff. I'm correct in assuming that a body lift doesn't bugger with that?
Ant
