Double light sidelights!
    That's a nice effective and easy mod, Vince. I think I remember seeing something i a bit like that, on Yota Tech, where someone spliced an additional orange indicator bulb into a Tacoma side light. Did you use four 5w bulbs? For extra brightness I changed my front sidelight bulbs to 21w capless. That works well. They're really bright. I don't suppose that I could get away with doing your mod and using 21w bulbs, though? Too much for the wiring harness?
    I used four 5w bulbs Mick, two 21w in each side would probably melt the light units.
      I have some 100w headlight bulbs, would it be a bad idea to fit these due to wiring strength?
      well, that was a bad idea!
        They would look a lot better than feeble sidelights you have at the moment
        Eat.Sleep.Surf.Repeat.
          HID sidelights anyone?...
              bright idea
