Has anyone on the forum got the above installed in the rear, I've just fitted an Ausie Locker in mine and would like to compare notes and opinions.
Auto Locker
uphill turns are a problem. locker only unlocks while coasting.
i have an issue at one intersection which is uphill with a tight turn. try and get a bit of speed up then back off the gas a bit. you don't have to slow down, just not accelerate.
worse thing is the sudden understeer when getting on the gas coming out of a turn. its enough to put you on the wrong side of the road.
i havn't had a chance to test it fully offroad. works ok on the little bit i've tried and its great on gravel road.
it feels a bit werid at times. when going slow, the locker locks and the load on the engine increases a bit and slows you down for a sec. a little quirk to get used to.
I agree on all those points. My missus hates the truck now, she just can't understand how to get it around bends and turnsWe'll see how it performs next weekend, then maybe put one in the front with a set of FWH. I guess she'll never drive it again
I had a lock right in my Cherokee and it was a right nightmare on the road and noisy too.....click click click every turn but offroad it was the complete opposite, completely silent and the extra grip just made hills and mud so much easier. When I have the money will defo get one in the rear of the surf.
mines been nice and quiet unless i boot it coming out of a turn, then it will give a big clunk and the rear will do a big shake.
no clicking or anything. not that you can hear much above the exhaust !
i hope you check the cross pin to spacer clearance.
one thing thats not in lockright manual but it is in aussie locker manual is that the clearance wants to be the same on both sides of the cross pin.
i certainly would not recommend a rear autolocker for a daily, especially for carting kids around, puke in the backseat!
Before I bought mine I did a lot of research on the US offroad forums, seems there are three makes of auto locker, the Lockright, Aussie, and Detroit EZ, they all ageed that the Aussie was the quietist and had first class customer service, so thats where I went. The price was also better at that time, worked out at £180 +£60 shipping dealing direct with Torque Tech, I was a tad worried about the gaps and settings but they were spot on, took me about two hours to fit it, an absolute breeze.
Go to direct Torque Masters
http://www.aussielocker.com
If you're putting it into a standard Surf rear then you will need model XD24930
Toyota V6.
Any one got one of these in the front? I've read a lot about the odd driving characteristics so thought the front may be a good idea, as with the surf 4wd set up and freewheeling hubs it would be completely disengaged on the road so no odd driving, in the mud it shouldn't matter so much about the affect on steering, just a thought
