i have ordered the first few parts for the lift i intend to do on my 2nd gen, so far i have 2" body lift kit, 2" spring spacers, diff drop brackets and 2" ball joint spacers.
When i get some more money i will be ordering roughtrax +2" springs and shocks, i will also be fitting manual locking hubs, and winding the torsion bars up to bring the front end level with the rear.
From what i have read over the last month or so i believe i will need some
front arb spacers so i can fit diff drop is this correct?
Will +2" shocks be long enough for what i have planned?
Is there anything else that needs to be modified for this amount of lift? (im guessing i will have to extend the rear brake line)
Also after the lift will i be able to run 35s?
Thanks in advance for any help.
