I am likely going to get the -32 offset (on the 10"), as I've looked a the gaps and I don't think there is any room to play with on the inside of the arch. All I'll end up doing is having to fit spacers anyway.
Even with the -32, I'll still loose a little inside room, so It will be touch and go.
On the up side, I reckon the front bumper end pieces and the front trim near the sidesteps will be the only bits to rub on the outside. Should be able to remove / hammer / adjust those with luck (famous last words!)
Take your words, put them on a plate, add a little bit of humble pie, and eat them!
Not sure if anyone's had any experience with these?
But it will be nicer to get some proper model specific wide arches in the long run. I've had a look about and can't find much for the 3rd gen. If anybody has seen some, please post a link!
Will let you know how I get on....
