Hello, I've lifted my 2.4 LN130 by 4" so far, 2" body and 2" suspension; my problem is this, I haven't got the money to change the shocks but I did have the skill and spare materials to manufacture some coil spacers and ball joint spacers.
From what I've worked out with a tape measure and some basic maths is that from under my rear arch to the ground I can acheive 38.25" at maximum shock extension (at the rear, stock shocks, 31x10.5" tyres, no body or suspension lift) which from standard height allows me an extension from settled height of 5.25".
After adding a 2" suspension lift but not changing the shocks that leaves me with 3.25" downward travel from settled height.
If I was to add a further 2" front and back without changing my shocks I will get 1.25" of down travel.
Is that or is that not enough until I can get the money together to change the shocks? A bonus is that the wheels, being held up by the shocks, will not travel futher than stock brake lines will allow but I am thinking that it just isn't a good idea.
What are your thoughts?
Thanks,
Ray.
Thanks,
Ray.
