rear fog light simples
  • rear fog light simples
    mines been like this since i first got it / did it instead of having a really naff looking piece of plastic crap hanging half smashed off the back of my car I did away with the drivers side reversing light wired the fog light wiring into it and put some red clearish tape over the lense works great and been fine for 7 years now just a suggestion
    Pictures would be even better.
    This is mine.
    http://www.hiluxsurf.co.uk/showthrea...ght=rear+light
      Mines the same, but someone has dipped the bulb in red paint... don't know the details, but it works a treat. looks stock aswell.
      www.johnthebuilder.info
        will try to sort some just thought it was a nice simples mod for people
        yeah like yours anythings gotta be better than the normal one eh
          the tape i used was from local petrol station for temperary repairs to cracked lenses etc
            Never even thought of doing it that way & it is probably the best way to go about altering the "naff" fog light that we've all had to replace at least once.
              never had to replace any piece of crap hanging off rear bumper...
              and can still see behind when reversing...
                Rav4, 4runner, LC?
                  Rav4, 4runner, LC?
                  1st gen, Surf with underslung spare, etc.?
                    Rav4, 4runner, LC?
                    Yes, yes and yes.
                    don't think so, no. etc.....
                      Confused..
                      Im with you Tony..stuck mine in the bumper too
                      For the reverse light folks, the red LED bulbs used for brake lights would be perfect (your brake lights are same wattage as fog lamps) just ensure you get brake light only, not tail-light/brake light combo
                        I intend to cut mine into the bumper once the weather improves.
                        I'm also going to cut some extra reversing lights in there 'cause I'm fed up of not being able to see where I'm going when in "backwards".
                        湯
                          I used one of these on mine.
                          I also fitted the rear lights from a surf with a rear tyre carrier so I have 4 reversing lights instead of 2. (still crap with the limo tints though )
                            As I have a big flat tailgate panel with no spare, I'm toying with the idea of using some thin lenses with low profile LED panel behind, and surface mounting them. Hoping to make something that looks stock too.
                              I'm thinking along the same idea and going to source some low-profile LED's for the bumper. I meshed, filled and sprayed the bumper, so doubt I'd get away with cut-outs in it. Might also fit front fogs, but do have a bullbar I can fix those to, unless I can find some that fit the recesses in the plastic bottom trim.
