just go this autobox oil cooler off ebay £24 all in not too bad its off a vauxhall omega 2.4
its about 600mm long just nice to fit between the chassis rails at the front of the surf! may need a bit of galved wall plate strap just to fix it in properly but with the brackets on should be an easy fit
they are ali so could bend into shape direct??
will post up some pics when done. i am putting it where the air con rad was as i got rid of the air con when doing the conversion so if you do still have air con im not too sure when you can fit it??
