Longer flexy brake lines.
Longer fuel filler hose.
Extensions to the gear levers.
Air sickness pills.
Brackets for the front bumper to raise it.
A step ladder.
Extend (or you may be lucky and have enough shaft to adjust) the steering column shaft.
cool, well just ordered some 50mm x 1000mm nylon rod
going to get some ht threaded rod, washers and bolts
cut the threaded rod to size weld bolt one side tighten up other.
debating wether to do a 3" or 4" body lift.
but want to get this puppy as high as i can.
so all the advice i can get dont want the truck off the road more then a day
