just been searching but can't find any custom exhausts..need some inspiration to knock one up..other than jus poking it out of the side..lol
Exhaust Inspiration..
 thats a good idea yea..got my fog light stashed there at the mo' tho.Originally posted by stormforce View Postcut a hole in the rear centre section of bumper and poke it out there instead.That way the exhaust can be tucked right up out the way then
 could incorporate into a new bumper
 Not had an exhaust (bar front pipe) since June..lol..kinda got used to the racket now, which aint that bad to be fair if your light with the throttle
 Yep, even with the window open an inch!Originally posted by hiroler View Posti was thinking of one like that do you think you might get fumes in the cab with the rear window open?
 http://s8.photobucket.com/albums/a41...rearendvid.flv
 not quite in the middle, but my fog light wiring got priority may tweak it when i get round to putting a different bumper on may tweak it when i get round to putting a different bumper on
 Cheers Rich,
 Done it in stainless from the frontpipe-back, will sort the frontpipe as and when it rots. The pipe kinked on one of the bends going over the axle but its only cosmetic, no restriction in flow.
 If i was to do another, i'd bend smaller lengths, then cut the bend out & re-weld into the finished pipe, rather than trying to bend multiple bends in one length..if that makes sense.? Would help with a better bender of course, i borrowed a mates clarke, just a press bender really, and without faffing and filling the pipe with sand etc you're not going to get the best results.
 its underneath and out of sight so it don't matter to much does it.
 My exhaust is stainless from the turbo back and i'm considering now about having another tailpipe made to come out the rear bumper.I can't off road much now so i'll just tart the truck up a bit so it looks half decent once the big lift is donehttps://www.facebook.com/groups/henpals/
