as fun as this, you're missing some important facts.
Basics...
Wastegates control boost pressure, BOV's control turbo lag and turbo wear.
On to the topic
1/ Surfs have a throttle plate, to make the EGR work, so shutting the throttle will produce compressor surge so a BOV should 'work' (ie make farty noises) IN THEORY. but still not much intake vacuum.
BUT......
2/ At a Surfs boost pressure you'll never notice it
FINALLY...
3/ try and increase boost pressure and turbine speeds to justify a BOV and the ECU will laugh at you and throw fault lights.
Leave it for the boy racers.
I'd guess ditching the throttle butterflys and EGR gives far more performance
Basics...
On to the topic
BUT......
FINALLY...
