Jimny Build {it begins}
  • Originally posted by dannyboy77 View Post
    what to see it in action!
    Brian / Alan
    is the lift to give the wheels more room under the arches when in the cross axled ruts?
    Yes mate, the last time out the rear wheels were flexing so much they jammed in the arches on the really extreme stuff. Hopefully this will give us enough.
    Brian
    • Diff removed and locker fitted. Hopefully will do us well at Col Glen Comp next weekend.
      Quite a few parts are not reused.
      Brian
      • Do I recognise that bench?
        That suzi looked good when I saw it and the roll cage was outstanding...
        .... Which was nice.
        • Originally posted by Overland Tonka View Post
          No mate that bench is in a friends workshop. It looked like rain so we took the indoor working option.
          Hope to give it a good work out this weekend when we hea to Colglen in Dunoon for a two day comp.
          Brian
          • Made this as an addition to the Jimny's kit
            Brian
            • Remember it won't fit in the Garage anymore.
              • Originally posted by Ploddit View Post
                It's an outdoor kinda truck.
                Next jobs.
                fit the SJ transfer box (underway)
                take the cage off and paint it properly
                fit the Grand Vitara rims we got and do away with the spacers
                replace the rad
                fit a new clutch (Colglen event was hard!!!)
                engine service
                Alan
                • good work as ever! i need to make one up too! might have to copy the design! hehe! well beef it up a bit! as the zuk is a bit lighter than the surf!
                  see you have your work cut out for the next couple of weeks with the mod list! oh BTW what size and gauge was the pipe you used for the roll cage?
                  have you had a chance to test the locking rear diff? what is it like to drive on the road and can you hear it kick in?
                    The anchor would work with the surf no bother, you could make a longer version and if you want and/or use the 50mm x 3.2mm tube. That tie bar in the picture is 14mm solid round.
                    I use 32mm x 3.2mm wall on the Jimny cages and 50mm x 3.2mm on disco sized trucks. The bigger tube would look good on the Surf mate.
                    The locker is excellent, it works by being locked all the time and only unlocks on tight turns and roundabouts. It clicks/ratchets when unlocking, hard to hear and by no means noisy.
                    Brian
                      But it will fit in my new one
                      Should be underway this weekend
                      Brian
                      • Jimny is going, will swap for a 3rd gen {petrol preferred}
                        I need a tow truck as I am hoping to build something similar to this, haven't told Alan yet but he likes a challenge
                        Brian
                        • Brand new radiator fitted tonight,
                          Clutch also new this week and has no miles on it yet.
                          I have removed painted and refitted the cage.
                          Brian
                          • So what do you do in your spare time
                            Or are you an insomniac like me ?
                            • Originally posted by Growler View Post
                              Now the weather doesn't matter to me I can spend even more time away from the TV and all these want to be singers
                              Update 20/04/12 Jimny has gone to a new home.
                              Brian
