Originally posted by dannyboy77
View Post
Jimny Build {it begins}
Originally posted by Overland Tonka View PostDo I recognise that bench?
That suzi looked good when I saw it and the roll cage was outstanding...
No mate that bench is in a friends workshop. It looked like rain so we took the indoor working option.
Hope to give it a good work out this weekend when we hea to Colglen in Dunoon for a two day comp.Brian
Originally posted by Ploddit View PostRemember it won't fit in the Garage anymore.
Next jobs.
fit the SJ transfer box (underway)
take the cage off and paint it properly
fit the Grand Vitara rims we got and do away with the spacers
replace the rad
fit a new clutch (Colglen event was hard!!!)
engine serviceAlan
good work as ever!i need to make one up too! might have to copy the design! hehe! well beef it up a bit! as the zuk is a bit lighter than the surf!
see you have your work cut out for the next couple of weeks with the mod list! oh BTW what size and gauge was the pipe you used for the roll cage?
have you had a chance to test the locking rear diff? what is it like to drive on the road and can you hear it kick in?http://www.hiluxsurf.co.uk/showthread.php?t=55797
Originally posted by dannyboy77 View Postgood work as ever!i need to make one up too! might have to copy the design! hehe! well beef it up a bit! as the zuk is a bit lighter than the surf!
I use 32mm x 3.2mm wall on the Jimny cages and 50mm x 3.2mm on disco sized trucks. The bigger tube would look good on the Surf mate.
The locker is excellent, it works by being locked all the time and only unlocks on tight turns and roundabouts. It clicks/ratchets when unlocking, hard to hear and by no means noisy.Last edited by yoshie; 28 July 2011, 01:01.Brian
Originally posted by Growler View PostSo what do you do in your spare time
Or are you an insomniac like me ?
Update 20/04/12 Jimny has gone to a new home.Last edited by yoshie; 27 April 2012, 10:50.Brian
