Fitted the spring tops to my LC springs today hoping that they'd pull the springs away from the shocks a bit more. But they didn't. One side has a gap of around 10mm between shock and spring, and on other side there's a gap of about a milimeter and the spring rubs on the shock when contracted. The shocks are procomp ES9000's. Has no one else had this problem? Any ideas why this is happening? What sort of gap do others that have fitted this lift have?
Springs rubbing on shocks.
I had/have the same problem, but i still have the old shocks on there, it improved when i fitted the spring tops but still just touches one side, i intended getting the procomps without the top shrouds but aint done it yet, it's only the shrouds that rub, have oyur got shrouds on?Too young to die and too old to give a toss
The springs are located correctly in the spring seat (so that the end of the spring sits against the notch in the seat so it can't turn anymore clockwise).
I can't really see how this can be fixed apart from getting new springs and/or shocks. Any idea if +2" springs will be ok with the +4" shocks or are they likely to bottom out when off roading?
