Hi all, joined recently and been using the site search feature to learn about the surf, Knowing naff all about diesels I'm slowly logging info into the 'old grey matter'. I have a blue 2nd gen 3.0td auto and with the info from here have now changed the timing belt with everything in situ, so thanks to all concerned. Today I have taken the dash apart to put new plasma dials on but have found that the speedo face wont go on because there is no hole cut out for the needle rest
. Do all surfs have the needle rests? hence faulty item, or are the dials for a different gen?
Any info greatly appreciated before I get in touch with the supplier.
Baz
. Do all surfs have the needle rests? hence faulty item, or are the dials for a different gen? Any info greatly appreciated before I get in touch with the supplier.
Baz
