LN130 Rear Locker codes Needed
  • LN130 Rear Locker codes Needed
    I have a 2.4 liter 2lt (soon to be 1kz te) 1992 Surf.
    I would like to install a rear locker but am unsure about the specs of the rear axle so cant decide which locker to buy.
    Preferably pls advise locker name and part # and a US based web site from where I ca purchase one.
    Vehicle info is as following:
    MODEL: Q-LN130W-GKPQJ. FRAME: LN130-7041185. TRANS/AXLE: A343 G145. ENGINE: 2L-TE
    This any help?
    http://www.summitracing.com/search/B...keyword=locker
      Yes it does.
      But I still have few questions.
      Surf: I understand that the rear axel is G145, I guess that it is 8", Limited Slip. But what is this 30 or 27 spline business? how do I know how many spline are there on my G145 Diff?
      Also what about the front axle? where and what is the code for that?
      I understand that on a 92 Surf, its 7.5 inches. But have no idea how many spline etc?
      Land Crusier II: LJ70RVKR , has 640/ G144, again am wondering what is the size / code of the front axel? what kind of a locker can i put on it?
      G144 rear.. 30spline? 27 spline? Can I fit any aussie locker? if yes then which one? part # ?
      Regards
      Sajid
        this is a good site. i cant get on it at work though so cant direct you to the section
        in the diff section he has pictures to identifty your diff.
        what lockers are you getting?
        http://home.4x4wire.com/erik/
          Good info, in fact too much info (-;
          I am looking for some kind of a locker similar to Aussie locker, cheap and reliable.
