Matt, the chip I'm using is a PIC16F677 - http://ww1.microchip.com/downloads/e...Doc/41262D.pdf
Tiptronic (semi-automatic) gearbox
That's exactly the one I was using at Uni, so it would certainly be compatible.Originally posted by MattF View PostI'll be nipping out to the workshop in a bit, so I'll dig it out and see what it is. If I recall correctly, I think it's a Microchip Picstart Plus, but I'll double check.
Andy
http://www.surfingafrica.net
Dug it out and that's the one.Originally posted by adpsimpson View PostThat's exactly the one I was using at Uni, so it would certainly be compatible.
Must be losing my touch. I've even kept the serial lead and original P.S.U with it. I'm a sod for just chucking those in boxes normally.
P.M me your address and I'll get it off to you.
Btw, do you want me to dig the software and books out for it too? Should have those knocking about somewhere, but haven't found, (fully looked), for those yet.
Hi guys, sorry I've slacked off posting here for a while.
I got this to the stage of a working prototype, but was thrown by a couple of things. Firstly there's a warning light comes on when the truck realises that it doesn't have control of the kickdown function any more, and secondly there was the slight niggling doubt that something I was doing was going to end up costing me lots of money in repairs.
The control logic is pretty simple - there are two output signals, which need to change according to two inputs. The counter chip took care of the current state. A third I/O is the lockup solenoid, which is semi-independent of the others.
However if anyone else is going to give it a go, I'd strongly recommend using either a PIC or an Arduino - Arduinos are probably the best idea, they come with a small programming board that you can slot straight into your computer, and are supposedly uber simple to work with. The control logic is the easiest bit - putting together the hardware (the signals each need controlled with a relay, and changing them can cause all sorts of spikes) is the hard bit. At least the Arduino simplifies that slightly - I had 10 ICs on my prototype board.
I got this far with no electronics experience at all, so it's really not hard. the chips are dirt cheap, I think I spent about £20 in total. My one fear is that the solenoids in the gear box may be more sensitive than I'm banking on and running them like this for a long time may damage them.
Matt kindly donated a PIC programmer to me for this an my current project, which I need to get back on to. It's related - it's a monitor for important temperatures, current gear etc, displayed on an nice wee screen in the centre dash. It's in a woefully unfinished state just now, but I'll be on it again soon.Andy
