anti roll bars remove
  • anti roll bars remove
    Has anyone took these off and did it give you any more travel on rear wheels.
    Not going to rest till its broke
    yes and yes
      yes , loads more articulation as well as loads more dirty pants going around roundabouts
      私のホバークラフト は鰻が一杯です。
        can you take them off the front toooo
          yes aswell
            now yur talkin
            私のホバークラフト は鰻が一杯です。
              i got both of mine off and with a 5" lift she leans over really nice and it stops people getting to close on bends and roundabouts
              Once i get the truck lifted 9" and the 38's fitted then i may need to re-fit them again but i'll need to get it lifted first and see what its like after
                fook it im riping them out, and going the fook over the top of roundaboots
                  ive just bought yoshies truck, same, 6" lift with both off and i can drag my knuckles on the groung when going round bends
                  私のホバークラフト は鰻が一杯です。
                    it is such a laugh when you look in the rear view mirror at the people behind when the truck leans over and looks as if its gonna turn over
                      I put my (re-bushed) front back on, mainly for the MOT this month, but it does drive better on the road with it on.
                      I'll be unbolting one drop link this evening at the campsite, and tying it out of the way with a cable tie. Until I make a proper disconnect AFTER the MOT. I can always buy a droplink then incase it all goes horribly wrong!
                        do you have to have them on for MOT?
                          If they're fitted as standard, they're supposed to be on for the MOT. Depends on how sharp eyed your MOT man is I suppose.
                            dam i havent got any i better get some then!! thought someone said if they was broken you fail mot but not if they wasnt on? dam STORMMYYYYYYYYYYY help
                              just remove them completly and any signs of brackets
