As a follow on from the thread in 'General'
I have roughed out a prototype design with a bit more elegance than a simple switch. I will post the diagram for critique later, but for now what happens is as follows.
Two momentary pushbuttons control 'lock' and 'unlock'. 'lockup' is input via a set/reset latch to a relay which switches the solenoid between either the ECU output or 12v, giving manual or ECU control of lockup.
Using the latch means its not possible to start the car in 'lockup'
The 'reset' portion of the latch is fed via a 3 input OR gate, the inputs of which are 'unlock' pushbutton, the 'brake on' signal and (the clever bit) also the 1st and 2nd gear active lines. This means lockup will automatically disengage when the box changes down to 1st or 2nd gear. It will also disengage when braking, which is a useful safety feature if you need to brake hard and forget you're in lockup!
So, to sum up. Manual lockup will be available in 3rd and OD. It will automatically cancel when the box shifts down to 2nd or 1st, or if you brake.
As this is in development, comments are welcome. The design will befairly flexible, but I am erring on the side of safety / reliability. I dont want to trash the gearbox!
 "Apache...The only man to stall a Auto"
