Ok I'm tired of bashing my rear fog light, plus I've now removed the rear bumper. So I've taken the adive from here http://www.showmesome.info/hilux/workshop/foglight.htm
But my reversing light is on the side rather than on the tailgate, so here's a write up for doing it.
Step 1:
Remove the rear driver's side light cluster. It's fixed on by 2 10mm bolts, then push out and pop off.
Step 2:
Locate the positive wire for your fog light (mine was red) and the positive wire for the reversong light (mine was red with a blue tracer)
Step 3:
Splice the fog light wire into the reversing light and seal the dead end of the reversing light wire.
Step 4:
Test to make sure everything's is working ok, then put everything back together again. All that's left to do is paint the bulb red, of get a red bulb.
Step 1:
Step 2:
Step 3:
Step 4:
