i have bean looking to get a set of axle & gear box breather hose and i have had a prop finding the f****g thing so i have found a place that has pos right
hose it is made from polypropoline is this the right stuff to get for making up gearbox & axle breathers the outside diameter is 8mm & the in side diameter is 6mm and the house is rated to 155 psi i know that that the psi rating doze not mater but will house do the job and i req ought else except cable ties
