suspension
  • suspension
    can a surf be given a sus. lift without the suspension being hardened ie like a disco-all sloppy
    Spring spacers on your existing springs?
      as std its as stiff as a board so spacers wont help
        take the arbs off and that will allow a bit softer ride i think
          i was thinking longer but softer spring if thats poss, maybe progressive rate springs
          after following that RR today it swallows the trail with ease where i was banging about like i had no sus.
            aahh right i see what you mean now John.But sorry i aint got a clue then mate
              What shocks have you got fitted?
              They might make it a harsh ride, mine do (ES9000)
              Tyre pressure will also make a big difference off road, I was bouncing all over the place on the Strata Florida, until I dropped the tyre pressure to 20psi.
              Also bear in mind that the RR is much heavier than the surf, and is designed to give a softer ride for the green welly brigade.
              Rob
              Still working for the man!
                standard shocks, havent even got a hard/soft setting, there like my old 2 gen on hard, tyres are at 2 bar 30 psi
