can a surf be given a sus. lift without the suspension being hardened ie like a disco-all sloppy
suspension
aahh right i see what you mean now John.But sorry i aint got a clue then mateOriginally posted by mud skipperi was thinking longer but softer spring if thats poss, maybe progressive rate springs
after following that RR today it swallows the trail with ease where i was banging about like i had no sus.
What shocks have you got fitted?
They might make it a harsh ride, mine do (ES9000)
Tyre pressure will also make a big difference off road, I was bouncing all over the place on the Strata Florida, until I dropped the tyre pressure to 20psi.
Also bear in mind that the RR is much heavier than the surf, and is designed to give a softer ride for the green welly brigade.Rob
Still working for the man!
disco now gone aswell
