Remove all rear trim, grab handles, front windsreen trim, interior lights, and the beading arounf the sunroof.Remove the four clips that hold up roof lining, it's best if you have an assistant to stop the lining folding.
Remove sunroof, once again it's best if you have a helper as the sunroof does get heavy after a while.
Measure, measure, measure and then measure again. Drill a small pilot hole, then the big bolt hole.
If you don't have a sunroof, or the rails you get are less than 5 foot you won't have to modify the sunroof mounting like we had to here. So forethought before purchasing your rails will pay off.
When fitting for the final time use plenty of goo to seal any gaps so you can't get water seppage.
Doesn't she look good. This is how they should have left the factory.
Many thanks go to Tony of 4X4 Toys in Basingstoke, as I was too great a coward to try this on my own. The end result is excellent.
