homemade body lift kits
  • #16
    cheers Nigel, i'll have a butchers, thinking of extending mine even tho i only
    got a two inch lift, not at all happy with fileing out the splines so the bolt will go in and only having about 10mm of splines for the clamp to grab on,
    yep if you extend the levers there gonna travel a bit more at the top so wont show the correct gear on the indicator, dont know how to get over that one,
    Drilling out the washers/spacers aint too bad, a lot easier if you got a decent 12mm drill bit which i did'nt, i used a round file about 11mm in dia cut off and stuck in a pillar drill in reverse, worked well, also the two mounts eash side at the front footwell and center pillar are already big enough to take 12mm bolts so you only have to enlarge six mounts,
    • #17
      Does anyone have any pictures or dimensions for the rad drop brackets and the bumper relocation brackets???
      • #18
        ask stormy,he got a real close look at them when he snapped his.
        www.overfab.uk
        • #19
          I'll have a look tomorrow and see if i still have one up in the garage for you.Got an even closer look when i hafd to take it out again
          • #20
            Rod, if you want some advice or would like to look at mine then give me a call 07872 614849
            I'm only in Bitterne and will be lifting the front of mine on sunday if you want to come over
            I NEED TO OFFROAD!
            • #21
              Ah that would be amazing mate!! I'll give you a call tomorrow, Any preferance on time??
