body lift+steering
  • body lift+steering
    hi all, hoping someone can put my mind at rest here. i did my body lift a while ago now and have just started to feel a knocking vibration through the steering wheel if i let the engine labour a bit.
    turns out what was left of the rubber grommet in the bulkhead has disapeared so the steering shaft is knocking against the body.
    i can get a good 3 or 4 mm play up and down on the shaft where it passes through the bulkhead, should i have any play there at all?
    did you not cut out any metal work from the bulkhead when you fitted the lift andy???
    www.overfab.uk
      This is summat i got to sort out haveing just done a 2" lift, not sure about the play, i take it you mean lateral movement, along the shafts lenght? i would'nt have thought it was too serious, but you might loosen all three clamps (one of em under the dash, which i did'nt loosen yet) file a bit of metal out where it passes through the bulkhead, jack her up and rotate the steering back and forth to let it settle itself in, retighten the clamps and check that UJ type coupleing at the front just to make sure its not broken up, fit a new grommet in the bulkhead, the play may be in the steering box,
      as long as theres no play when your turning the wheel, (or very little) it should be OK
        no i didn,t Mark my blocks were about 45mm it looked as though i was going to get away with it but will cut a bit out now.
        got to have a proper look in daylight yet only noticed the play feeling around in the dark last night. thanks for the replies
          no play at the sterring wheel, if i get hold of the shaft where it passes through the bulkhead hole i can make it move about quite easily making it knock against the bottom of the hole
            its possible that youve damaged a uj.have a look and make sure the shaft isnt just moving on the splines.its funny that you didnt get any graunching noises.or heavy steering
            www.overfab.uk
              bugger cheers mark will have a look i did notice a bit of graunching noise briefly a couple of weeks ago. that will teach me to rush the job
                Glad I read this - I'll need to make sure I keep this in mind when I do the lift soon
                  Without lenghtening the steering rod you won't have a lot splines left in the steering UJ's, now I aways sleeve and lengthen the rod so it sits in the splines properly.
                  Here's Logeys one I did last week.....
